Old 05-01-2006, 10:56 AM
speed220mph's Avatar
speed220mph speed220mph is offline
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
HSSS427: I hate to butt in again, but my car is also an ERA with slip-fit primaries. These may fit loosely when cold, but swell when hot to seal the joint. One problem that is created when a header leaks is the header and head errode around the exhaust ports under the gasket, ensuring that a new gasket will leak. I had to mill the exhaust-header mounting face on both the head and headers to fix the leak. You already know how The backfire on my engine was fixed by pinning the cracks in the old tunnel-port heads.
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
