Old 05-01-2006, 11:15 AM
azjulian azjulian is offline
just to answer your previous question on re-jet of the demon...
if you have ported your heads and changed cam, then you will have increased the airflow into your engine - its entirely possible that the ratio fuel to air is still correct to the setup that you were given - you just need to make sure that you are not running too lean.
