Old 05-04-2006, 12:37 PM
edwhite7 edwhite7 is offline
Cobra Make, Engine: Contemporary, Shelby Alum 427, Dove heads
Be careful not to make the bead to thick. If it is to thick it may block off the head oil drain back passages. If you have the breather port in the back of your intake you can use an inspection mirror to check if the passages are clear after installing the intake.
In school 90% is exceptional, in life 10% wrong is failure.
