Old 05-06-2006, 08:51 AM
turnpike boy turnpike boy is offline
Cobra Make, Engine: Unique 427SC/331/5 forward
For the most part all that stuff will go right on. The reverse rotation pump will also work, but you might want to check it against the cam cover to make sure bolt pattern is the same. You will also, obviously, want to run it in the reverse direction....
Some brackets might not fit; depends on what you have. You may also find some brackets fit but put the accessories too far out/forward for the serpentine belt.
Manifolds, headers, etc. are all the same and will fit right on.
