Old 05-06-2006, 02:24 PM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
I noticed you have a Jag IRS rear end---have you got modified hubs, pin drive adapters, custom wheels, etc?????
The stack up of tolerances could give you a resulting almost uncurable shake---
Start at the u-joints and verify there condition--then hub wobble and runout--verify the wheel mounting face is parallel to the mass of the wheel(lip run out) Bolt or pin drive circle could be off in either the hub or wheel
When you verify every thing is zeroed out then mount some tires
Put wheels on the same stud or pin every time.
Jerry
