Thread: Pedal Assembly
Old 05-06-2006, 01:48 PM
dscott's Avatar
dscott dscott is offline
Cobra Make, Engine: Owner, Classic Roadsters II
There are 4 nuts that hold the box to the booster, 2 bolts that hold the angle bracket to the firewall at the top of the box, you must remove the throttle cable at the pedal, the 2 wires to the brake light switch, and the clutch cable. The clutch cable is held on with a pin and clip, or some people use a bolt through the eye of the cable with a lock nut.
Don
