05-06-2006, 06:04 PM
Il
Cobra Make, Engine: Coupe,Blue w/white stripes SB; Roadster, Blue w/white stripes BB w/2-4s; SPF installer/Hot Rod-Custom Car builder
As Tongue Pirate alluded to the high spead idle cam on the choke may be sticking. It also sounds like you could have a vacuum leak or lean idle circuit, when you drop off throttle the engine is still pulling fuel from other than the idle circuit to compensate for the leak or lean circuit.
WDZ
