Old 05-07-2006, 01:05 AM
Keithc8 Keithc8 is offline
Default Engines built for Cobras
We have developed a few new SBF crate engines just for the Cobra builders and Club Cobra members. Why buy a crate engine that does not have the right oil pan, camshaft, brackets or water pump for your Cobra just to have to change these things or have them not look right for the car.
Econo Crate 331C.I. SBF 302 engine, fullymachined 302 block, Eagle 3.250 cast steel crankshaft, Eagle I-beam rods, JE/SRP pistons, KCR hydraulic roller camshaft, FR double roller timing set, stock front cover, Edelbrock water pump, Canton T-style oil pan, Melling HV oil pump, FR hydraulic roller lifters, Edelbrock Performer RPM or Brodix 5.0 aluminum heads, ARP head bolts, Comp Cams pushrods, Scorpion roller rockers, Edelbrock Performer RPM intake, KCP logo valve covers, MSD distributor and gear, KCP wires, Holley 750 HP vacuum secondary carburetor, March pulleys and alternator bracket, alternator and belt and steel flywheel balanced to engine. Comes completely balanced with balance, build and dyno sheets. This engine will make 425 ft/lbs torque and 435HP. Complete package 7695.00
Standard 331C.I. SBF crate engine the same as above with these changes, Eagle 4340 steel crankshaft, Eagle 4340 H-beam rods, Edelbrock Victor JR intake, KCPE CNC ported AFR 185 or Brodix 5.0 heads and larger camshaft. This engine will make 440ft/lbs torque and 480HP for an up-grade of 900.00.
Econo 408C.I. SBF 351W engine, fully machined 351W block, Eagle cast steel 4.000 stroke crankshaft, Eagle or Scat I-beam rods, SRP or Mahle pistons, KC hydraulic roller camshaft, FR double roller timing set, stock front cover, Edelbrock water pump, Canton T-style oil pan, Melling HV oil pump, FR hydraulic roller lifters, ARP head bolts, KC CNC AFR 185 or Brodix 5.0 heads, Comp Cams pushrods, Scorpion roller rockers, Edelbrock Performer RPM intake, KC valve covers, MSD distirbutor and gear, KC plug wires, Holley 750 HP vacuum secondary carburetor, March pulleys, alternator bracket, alternator,belt and steel flywheel. Balance, build and dyno sheets provided. This engine will make 525 ft/lbs torque and 520HP. Complete package 8495.00
Standard 408C.I. SBF engine the same as above but with these changes, Eagle 4340 steel crankshaft, Eagle 4340 H-beam rods, Edelbrock Victor JR intake, KC CNC ported AFR 205 or Brodix Track 1 heads and larger camshaft. This engine will make 540ft/lbs torque and 527HP for an up-grade of 1100.00
We feel that we have created some of the best possible crate engine for the dollar anywhere. You get our same great work and quality but at a great package price. Name brand parts, quality workmanship, reputation and built for the Cobra owner, now thats a crate engine. Feel free to give me a call about your Cobra engine needs. Thanks, Keith Craft
Keith C
