Old 05-07-2006, 04:11 AM
JCoop's Avatar
JCoop JCoop is offline
Cobra Make, Engine: Superformance, FRP460 Big Block
Thanks all for the analysis. No choke, mechanical secondaries. And the vacuum advance is plugged. I DID split the vacuum source for the PCV and brake assist servo. It was "T" fitted to the base of the carb, so I got a fitting to the manifold and ran the brake servo there and kept the PCV to the carb. I'll check those connections for leaks.
I haven't tried to replicate it at rest and with the air cleaner off. I'll check that too. It seems to happen when the temps have gone up to op temps; not when cold.
Ray
New York
SPF#1052 11mpg
CAV GT40 MONO29 9mpg
'01 MB CL600 V12 18mpg
'08 Volvo S80 18mpg
