I had to up the CFM on my fan to 3800. I tried the 16 " multi-blade units rated at 2200, didn't cut it.
I also increased the water pump speed by dropping the crank pulley diameter.
May I suggest you check the rubber mounts for the radiator while you are at it, they wear away over time.
