Old 05-08-2006, 12:14 PM
HighPlainsDrifter's Avatar
HighPlainsDrifter HighPlainsDrifter is offline
Cobra Make, Engine: F5 Roadster
Default 1967 Cobra 427 S/C replica
I have a shell valley cobra for sale:body re-inforced with kevlar.
registered inspected and licensed in Jan '99.
Fresh 5 liter, .000/.000 crank, forged pistons, trick flow roller cam, ported E7 heads,Edelbrock RPM intake,600 Edebrock carb,oval air cleaner with k&n filter,cobra valve covers,MSD 6AL,coil and 8.5 wires, new dist,starter,water pump,rad fan.
Narrowed 9" Ford rear with Currie 4 pinion possi and 3.25 gears,Dutchman forged axles, aluminum 4 link with comp engineering panhard bar.
Coilovers on all 4 corners with tubular front A arms.
NHRA legal rollcage and will tech to 11.00 ET.
Wood dash with phantom white autometer gauges.
B&M ratchet shifter,bang one gear at a time.
PA - NEW performance automatic street/strip AOD and 2,400 stall converter.
Black ghostflames with frost white tips over front fenders on PPG claret red paint/clearcoat.[can only see them in sunlight] no stripes.
Will be at WSCB in Reno ,May 19-21.
Set up for cruising with tig welded aluminum gas tank.
Offered @ $ 37,500 US obo.
pb_korness@telus.net
