Old 05-08-2006, 01:46 PM
khansmith's Avatar
khansmith khansmith is offline
Cobra Make, Engine: Hurricane Motorsports, Southern Automotive 428 FE
Originally Posted by 2KWIK4U
I think Clois was referring the using the load leveler on the corners of the intake, not the carb flange. I, also asked the questions you are, while installing my FE. I think the thread was titled "Do you trust engine lift plates". Several said they would use them on a small block, but not a BB. I used the bolts in the end of the heads, front left and right rear, since they are larger diameter bolts.
Brad W.
I understood this. the lift plate is a seperate application than the load balancer. I might want to use one or the other as I have both.
I don't have a trust issue with the lift plate. There was a great article in Mustang magazine this month about lift plates. not worried about it breaking. I just want to know if the bolts that mount the carb to the engine are strong enough or if I have to get stronger ones. I still would like to know if anyone has the answer.
Hurricane Motorsports: HM1046
Follow the build on my blog: http://khansmith.blogspot.com/
1974 Pantera resurrection blog:http://1974pantera.blogspot.com/
