Old 05-12-2006, 07:40 AM
bkozlow bkozlow is offline
Cobra Make, Engine: built the molds and body composite construction
My only warning would be to remember that brake fluid is the most effective paint remover you have ever seen. When bleeding a system, I get from Home Depot a roll of 5/16 clear plastic tubing and attach it over the breeder and bleed into the plastic line. It lets you see the air in your system and place so it becomes the highest point in your system. When you are done squeeze it at the bleeder and remove carefully so as not to get any on anything on your car. The tubing costs about $2.50 a roll and when done I just throw the whole thing away.
bkozlow
