Old 05-13-2006, 09:17 PM
HighPlainsDrifter's Avatar
HighPlainsDrifter HighPlainsDrifter is offline
Cobra Make, Engine: F5 Roadster
Default More in it
Hi,
Not bad for 1st run.
You are lean at the carb,go up a jet size in the primaries and put a metering block kit on the seconday's and try again.The AF ratio should be 11.8 to 12 under full throttle.Put a k&n flow top on the air cleaner also. Add 2 degrees timing only after you richen it up.
Good luck,
Perry.
