Thread: Clutch Cable
Old 05-14-2006, 06:08 PM
aggie76 aggie76 is offline
Club Cobra Member
Cobra Make, Engine: N/A
Default No pictures, Sorry!
I was so anxious to get things back together, I did not take any pictures.
Basically, I removed the pulley, cut away enough material around the pivot point of the quadrant to clear the welds on the stock pedal, and then mounted the quadrant so its outer rim was in the same place as the OD of pulley had been. I used two 1/4-28 bolts to attach the quadrant to the pedal assembly.
Alan
Never ascribe to malice that which can adequately be explained by inattentiveness.
