Thread: London Show
  #22 (permalink)
Old 05-18-2006, 05:51 AM
rdorman's Avatar
rdorman rdorman is offline
Renegade Nuns on Wheels
Mid-Ohio has good run off room in the areas where it is really needed. As for tires, you know what higher performance tires do? They reduce the range of slip angle at the limit. What does that mean? Higher cornering speeds and less forgiving. If you have ever driven a race car on a track on racing slicks, you know what I mean. There is a VERY fine edge to balance upon. A street tire will create its max grip over a much, much broader range of slip angles and give you a LOT more notice before you go spinning of the track.
Racing tires increase corner speed, reduce the amount of warning before they loose grip and increase your chances of an off track tour if you don't know how to handle them! They are for experienced drivers.
If it where me, I would prefer to be running on plain old street tires for my first couple of times out. And as always, use your head and don't drive above what you can handle!
This is a school, so check with your insurance agent, mine WILL COVER ME and the car during a school. I have it in writing!
OhioCobraClub.com
LondonCobraShow.com
