Old 05-22-2006, 03:35 PM
Art Burtt Art Burtt is offline
Cobra Make, Engine: Classic Roadsters 351 Windsor 405 HP
If you have some pieces of fiberglass left over from cutting out the head light hole for instance, use a hole saw to cut a piece to fit the hole. Use some fiberglas mat and resin to hold the piece in place. I used saran wrap and duct tape to hold it until it set. By the next day you'll be able to sand it and it will look like the hole was never there. I drilled the wrong sized hole for my interior lights and used this method to just "glue" the piece back in place ,then re-drilled the hole to the proper smaller size. It worked like a charm! Resin and mat should be available in any parts store.
