Old 05-24-2006, 03:52 AM
strictlypersonl strictlypersonl is offline
Unfortunately, Spax has changed their design several times so a fix (or the problem) may not be consistent. I believe Ron has a damper with a top fitting welded to the shaft and it may be that there's some excess weld interfering with the fit of the spring perch. Some dampers have a screw-on top with black powder-coat on the top and spring perch.
