Old 05-24-2006, 08:02 AM
Steve S. Steve S. is offline
Default Factory Five 2320 For Sale
If you’re looking for a pro-built Cobra Roadster sorted out and ready to go this is for you. Health issues and other interests have influenced me to offer Factory Five Racing Roadster FFR 2320, for sale. This car is a real head turner, has won “Top 5 Award” from Cruisin’ Magazine and has been featured in the Cape Cod Times. The car is located in Marstons Mills, MA about a half hour from Factory Five and will be at the Factory Five open house.
INTERIOR
Black with classic black vintage seats
Simpson 4-point racing harnesses
Fully insulated driver and passenger compartments
Classic gauges with reverse reading 180 MPH electric speedometer
Cooling fan override switch
Aluminum AC brake/clutch pedals
Lokar chrome gas pedal
Tempered glass wind wings
Sun visors
Adjustable driver’s seat
Battery cut off switch
Fire extinguisher under dash mounted
MotoLita 14 in. wood steering wheel
Column mounted turn signal and high beam switch
Hidden 12 volt receptacle
Extra fuse panel and ground plate
EXTERIOR
Chrome plated roll bar
Quick jacks
Team III 17” deep dish polished wheels
Yokohama A250 tires 235/45Z17R17 275/40ZR17
Wheel well lips filled and finished
Wheel wells undercoated, black
Underside of hood finished and painted
Clear spats
Body painted by Dartmouth Auto Body
BMW titanium with dark blue metallic tapered stripes and pin stripes
MISCELLANEOUS
Hood hinges
Hood gas struts
Trunk hinges
Trunk gas struts
Black side pipes
Silver epoxy painted frame
Polished aluminum panels, engine compartment, front end opening and trunk
Custom hidden battery compartment under truck floor
4-wheel disc brakes
Brake proportioning valve
Braided stainless steel brake lines
Flaming River 15:1 steering rack
Rag joint eliminator
FFR tubular front lower control arms
FFR adjustable upper control arms
FFR bump steer kit
Independent Rear Suspension
Pin Drive
Vintage Performance solid aluminum and poly IRS and differential bushings
Drive shaft safety retainer loop
3:55 FMS gears
McLeod scattershield bellhousing
ENGINE
1993 302 cu. in. block, bored .030” over
Professionally built by Beach Performance, Albany, OH
Balanced and blueprinted
Crankshaft – FMS
Rods – FMS
Pistons – Speed Pro Forged 9.5:1
Timing Chain – Cloyes
Cam – Lazer custom ground hydraulic roller, FW HR 281A 287B, 228/234 @ 50,
total lift = 550, 1.06 centerline
Push rods – Smith Bros.
Valve Springs – Crane BB chevy true dble. springs
Valves – Manley
Rocker arms – Comp Cam forged roller rockers
Rocker posts - ARP
Heads – World Products Windsor Jr., steel, professionally polished and ported
Intake manifold – Edelbrock Air Gap
Bolts – ARP
Carb – Edelbrock 600 CFM
Fuel pressure regulator – adjustable with gauge
Lokar Braided Stainless Steel Throttle Cable with dual return springs
Headers – FFR (Hooker) 4 into 4, ceramic coated
Header gaskets – Earls prof. Polished and ported, w/BB chevy true dble springs
Ignition system – MSD 6AL
Coil – MSD Blaster
Tach. pulse feed – MSD
Under pulleys – March
Radiator = Griffin aluminum
Cooling fan start top switch - adjustable
Oil pan – Gordon Levy, 8 qt.
Distributor – MSD billet
Water pump – reverse rotation
Spark plug wires – FMS 8 mm, blue
Valve covers – Edelbrock, finned aluminum
Breathers – Edelbrock, chrome
Air filter – K & N Xtreme high volume
Remote oil filter – mounted on X brace
Oil filter – K & N Gold
Oil pump – high volume
Engine oil – Mobil 1
Transmission – T5
Transmission oil - synthetic
Rear end gear ratio – 3.55 :1
Rear end oil - synthetic
CONDITION
Excellent condition – 6800 miles – oil and filter changes about every 1000 miles. The car runs perfectly and needs nothing but a new owner.
I am offering the car at $38,750. I can be reached at 508-364-3400 or by email at ssheftel@comcast.net
Steve S., FFR 2320
