Old 05-25-2006, 05:18 AM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
Dave has some very good points but I am inclined to think you need to check your timing and how lean your carb is running. Also, have you burped your water system. Do this by loosening your water temp gauge (cold engine) and starting up the engine leave this fitting cracked open until all the air in your system has purged and water starts slowly leaking out, then tighten. Also, how is your oil pressure?
Clois
"Let's roll"
"Be part of Something Good
