Old 05-27-2006, 03:28 PM
grumpy grumpy is offline
Cobra Make, Engine: Self Built, 427 USRRC, 427FE, Toploader
Hyde,
If they don't, I can send you a right/left 3/4" woven roving torn to the bottom of the shape and a quart of the black. Then it would be a simple matter of wiping the bottom area of RL foot boxes with acetone to beak down the surface for good adhesion, tape off any overlaps, splice areas, etc, to eliminate the resin from running thru. Lay in the 3/4 oz. and with a 1"-1.5" pure bristle brush load up the roving until saturated, let cure, then spray with semigloss urethane on the sides and the new bottom. As it wears off from use you will never know it since the layer will be over 1/6" thick and wear like the devil.
grumpy
