Thread: Sway Bars
Old 05-27-2006, 07:33 PM
Aussie Mike's Avatar
Aussie Mike Aussie Mike is offline
Craigs car is the generation just before ours. It has pretty much the same chassis but Ian moved the front suspension pickup points out about an inch on both sides on our kits. This was to reduce the scuff radius on the front wheels. If you look closely at the pics of craigs car you will se he has more dish on the froth wheels than the later cars.
Rear sway bar mounts are for the factory Ford Au rear bar. Dont make the mistake I did of buying an after market bar because they are a different shape and hit on the diff mounting. The only problem with the Ford bar location is that it's a bugger to get to.
I think Ians newer cars run rear sway bar mounts on the bottom of the chassis and run the bar under the lower control arms.
Mike Murphy
Melbourne Australia
