Thread: Help!
Old 05-27-2006, 07:40 PM
go300mph go300mph is offline
Cobra Make, Engine: Innovative, , 302, medium mild
Default Clogged
You have probably gotten the screw head loose by now but if not what about sticking the wire from a MiG to the screw head, set MIG up hot and pull trigger then touch screw head at same time as releasing trigger, hold for a second and then draw some wire and snip off then pulllllllllll. I can do it all the time when I am not trying to, it is tricky when you are trying to do purposely but it is very strong when it works pull dents out of cars using this method all the time. Be sure to disconnect the battery and any computers first, good luck
Mick
