Old 05-29-2006, 08:06 PM
cobred's Avatar
cobred cobred is offline
Cobra Make, Engine: ERA #698 428 Toploader
The oil comming out of the breather is the least of the problem, probably from the heat. I would take off the belt and see if the engine turns over. If not, drain the oil into a clean container and look for a metalic color, you probably have a magnetic drain plug. Check it for metal. That may tell the whole story. If you do have metal call Keith and ask his advice. Best of luck.
