Old 05-29-2006, 07:29 PM
cobred's Avatar
cobred cobred is offline
Cobra Make, Engine: ERA #698 428 Toploader
Mark, tighten the hose by hand is enough. Are you trying to fill the cyl. and then removing the air supply? You have to leave the air connected untill each valve is done. Also. keep the trans. in neutral so the engine will turn each time you plug the air into the next cyl.
