Thread: light switch
Old 05-30-2006, 07:25 AM
rnunn rnunn is offline
Cobra Make, Engine: KMP #248, 427 so, 4spd, 3:31 salisbury posi
Default light switch
Have any of you guys changed the wiring on your car when you flip up one way the running lights burn, then the second way the headlights/running lights burn. Currently the first tab does not do anything different from the second tab.
Looking at mine the white/blue stripe wire is connected to the same pole as the brown wires. Then you have a seperate red wire (i'm assuming the hot wire) and a blue/yellow stripe wire.
Also, i can't get my reverse speedo to work. I installed the gear from Finishline to the back of the gauge but no luck. I'm afraid it may be in the transmission part. Any thoughts?
Thanks,
Robbie
