Old 06-02-2006, 03:56 AM
cobbindale's Avatar
cobbindale cobbindale is offline
Cobra Make, Engine: Classic Revival.
Hi All,
Can anyone tell me why the later model column cannot be used over the unit mentioned in the manual.
What are the differences between the two columns (apart from the upper mount measurments)?
I have altered the upper mounting bracket to suit the later unit and now wonder why everyone insists on the early unit. Are the dimensions between boss taper to upper mount to lower mount different between the two?
Gav, would you be able to measure both of them to see if all other measurements are the same and also the cowling shape? Could be I have stuffed up yet again.
Dale.
