Old 06-04-2006, 12:03 AM
DavidNJ DavidNJ is offline
Originally Posted by Keithc8
The problem with the small chamber as you describe it is that it kills the flow down low where most street engines need it. I had to open the chamber up to about 80cc to get the valves un shrouded.
I didn't understand what you meant by 'small chamber...kills flow down low'. Could you elaborate on this a little more?
Do you port the BT heads yourself or use ET or similar shop? Was the unshrouding part of the CNC?
And finally, how much are they?
Thanks,
David
