Old 06-04-2006, 08:28 AM
Brent Mills's Avatar
Brent Mills Brent Mills is offline
Administrator
Originally Posted by Power Surge
Why is it that you can bolt an OEM bellhousing to any motor, but you have to index the Lakewood on every block it's installed on? I can understand having to do it the first time out of the box due to production tolerances, but once it's been indexed to one FE motor, shouldn't it be good for any motor? If not, then that would mean you'd have to index ANY bellhousing, OEM or not. Just trying to make sense of it and not have to make more work for myself if it's not needed.
I'm pretty sure it's that the engines themselves may have some differences....You may be able to mount an OEM belhousing to any block, but I'm guessing that the folks in the know check and adjust accordingly. Better safe than sorry later, and it really probably will be easier to install the engine with the belhousing attached and then just slip the end of the tranny in.
