Old 06-07-2006, 09:37 AM
rob frink rob frink is offline
I use a manually operated by-pass valve. It is integrated into the remote filter mount.
It allows me to proportionally flow as much oil as I want through the cooler. It has -12AN ports for low flow restrictions.
I run -12AN from the engine to the valve/filter. Then -10AN to my oil cooler.
I think my oil temp runs on the cold side most of the time, even wit the oil cooler closed. But when I drive with higher engine revs, say maintained at 3500 and up, the oil temp gets dangerously hot and I need the cooler. At a track event for example.
More info on these valves are at: www.beaumontmetalworks.com
