Thread: Fender Flares
Old 06-08-2006, 07:22 AM
TonyMadrid's Avatar
TonyMadrid TonyMadrid is offline
Cobra Make, Engine: A&C 351W, C4
Default A&C Alignment
Have you spoken with Joe at A&C? He is really very helpful when it comes to tech support for the build.
Regarding alignment, I know that the frame outriggers are different lengths when measured from the main frame rails. One side (I forget which side) is one inch longer than the other. This is important when mounting the sidepipes. However, if you center the body on the frame, relative to the main frame rails, you should have no problems with fender flare clearances. The only thing I can think of would be the ride height, which if set too low could cause a tire to wheel well clearance issue.
Before you cut anything, call and speak with Joe.
Good luck and let us know how you make out.
Tony
