Thread: DRB Rear Ends
Old 06-08-2006, 02:44 PM
400TT's Avatar
400TT 400TT is offline
Going with Commodore rear, then adaptor kit for reasonable Commodore(like VT) brakes for the front. Then wheel stud and offset will be pretty well right for any upgrades.
This will allow you to eventually upgrade to the larger HSV front & rear rotors. And/or put on Skyline 4 piston on front, Skyline 2 piston on the rear. And none of this will affect wheels. Not sure what size you are thinking, but will need 16" wheels to clear these options. 17" would be sweet. Depending on rotor size, Skyline 4 pistion calipers can be a bit of a squeeze. You could always run some cheap aftermarket Commodore wheels.
Yeah, since you have them, go with your existing springs & shocks. You can actually upgrade later to koni's or AVO's without affecting anything else.
www.absolutepace.com
