Old 06-11-2006, 07:33 AM
jarendall jarendall is offline
Cobra Make, Engine: StreetBeast 66 replica 302 350HP
the clutch plate will slip when worn out, you seem to have a problem with the TO bearing or the slave cylinder, also you might want to check your fluid level for the master cylinder, sharpe 1 suggested, that you may have air in the system, that could come from a low level in the master cylinder, check for leaks
PapaJohn
