Old 06-11-2006, 06:54 PM
Streetwize Streetwize is offline
Cobra Make, Engine: Midstates 427" Stroker Smallblock with Trick flow heads
I run a 511hp 427W in my cobra with the 3550, I've drag raced all brands for 20+ years. With the light weight of a Cobra and limited traction (assuming you're not running Drag Slicks) I feel the 3550 is more than adequate for normal street to moderate road race use. There were guys running in the 9's in Fox body mustangs on slicks and 3100lb body weights back in the early 90's with T5's, the weak link was third gear.
The TKO is a stronger unit, it holds up in 600+ lb/ft Musclecars with the Keisler conversion kits, but most of those cars are 3600+ pounds. When you are accelerating heavy mass from an instantaneous start with little to no tire slip, that's when those bigger input shafts and bearings really come into play, but in a lightweight Cobra, it's really overkill IMO.
Wize
