Old 06-14-2006, 01:42 PM
strictlypersonl strictlypersonl is offline
Originally Posted by HSSS427
The fun never ends does it on these cars.....
Was looking at the tires and found the left rear severly wore on the inside portion of the tread. The tires are Goodyear big letter slicks with tread cut in to them from Roger Krause. Probably have a total of 1500 miles on them with one 2 day track event last year when they were brand new. Relatively minor track wear as it was my first track event ever!
Based on the signifcant wear vs the right rear, I have to believe this is an alignment issue of some type.
Any suggestions based on past experience? I'm also going to send the pics to Roger Krause and see what they say.
Improper toe-in will cause tread feathering, but that also happens with lots of track work. I don't see any of that on your tire anyway. Nor do I see uneven wear from the inside to the outside of the tire, so your camber seems pretty close. I think that the tire was internally non-uniform, causing the uneven wear.
