Old 06-15-2006, 12:22 PM
pmfranke's Avatar
pmfranke pmfranke is offline
Cobra Make, Engine: B&B 351/402 Fi roller everything
wish i had ! it is better done with body off ,then you can weld a plate under the battery just like the other side (only make it as big as the battery so you can bolt it down threw the plate).then all you have to do is move the gas filler tube to the front of the gas tank using the existing attachment hole (cut it out) and plug the rear hole with a plate ( use seal all,gas resistant sealer.works great bought at wall mart 2.00$)buy a rubber extention from a boat shop and viola !!!!!!!!!!! u got the best set up.probably under 40 bucks. well worth the time to do.more room in the trunk too.better weight dispersal also.Please do it and take pictures!i cant figure out why b and b doesnt do it.Just to save 20 bucks?????
the older i get the faster i was.
