Old 06-16-2006, 08:53 AM
Eljaro's Avatar
Eljaro Eljaro is offline
Cobra Make, Engine: Contemporary with 482 KC/SO, TKO600,IRS Jag/AMP, 3.54 Salisbury PL,
When I got my TKO600 it said in the instruction sheet to use Dextron III type ATF fluid.I use Castrol. I could not image such a big gearbox to shift so easy and so fast. Wonder why the 3550 should use a different oil.
The only leak was where the the speedo cable goes into the box. Some O-rings in the right place fixed that.
Nothing sounds better than a Cobra in a Tunnel !
