Old 06-16-2006, 11:10 AM
Humbucker's Avatar
Humbucker Humbucker is offline
Cobra Make, Engine: Superformance #1408
Originally Posted by Eljaro
When I got my TKO600 it said in the instruction sheet to use Dextron III type ATF fluid.I use Castrol. I could not image such a big gearbox to shift so easy and so fast. Wonder why the 3550 should use a different oil.
The only leak was where the the speedo cable goes into the box. Some O-rings in the right place fixed that.
I too would think a good o-ring would solve that. As for the difference in oil, the guy I spoke to yesterday said the TKO500 & 600 gears are cut with a slight rounding of the edges to make them less noisy than the 3550.
I'm going to switch back to the Redline C+ that was in there before and see what happens. If there's a leak, I'll try the o-ring (I have about 50 of various sizes around the shop) and let you know, if you don't beat me to it.
Jake - Ringgold, GA
Superformance #1408
