Old 06-18-2006, 07:47 AM
elpontoge's Avatar
elpontoge elpontoge is offline
You should be able to design your own chassis these days with ideas from the various Cobra manufacturers who advertize online. Many give the specs, and everyone knows you will use a 90 inch wheelbase. Track dimensions can be fit to your own body...suspension can be based on existing coilovers that are available almost anywhere. You can buy upper and lower a-arms and rear trailing arms. Start with two 4.0 inch round steel tubing .125 wall thickness that fits between the ends of your body and just do some research. You may also use 2X4 rectangular tubing as well...just make sure it is at least .125 wall thickness. You're making a custom chassis, it does not have to be Shelby accurate. As long as you can weld and measure, you can find a way. Visit all the Cobra manufacturer websites and just do it.
Thanks .... i saw your gallerie .... My chassi will be like yours .. i have the same idea in my mind ..... but i will use a front suspension of GM OPALA , that everybody use here in brazil .... and in the rear i will use a solid axel rear suspension.... i will post some photos of a chassi that i make in 3dmax8 ... it isn't the last idea . everyday i have new ideas when i see other chassi photos ... rsrsrs ... see my gallerie tha you will see ... .... but i need any help that appear about chassi ......
are you engenier or something like this ?
thank you man !
