Old 06-18-2006, 08:21 PM
HSSS427's Avatar
HSSS427 HSSS427 is offline
Cobra Make, Engine: ERA #414 427 s/o w. Shelby Aluminum heads, Edelbrock Performer RPM Intake, Mighty Demon 750, Tremec TKO 600
Swapped emails with Keith Craft this afternoon. He pressure tested the heads to 35 psi. He's expressed some worry that the heads might have cracked when I torqued them down.
I was by the Summit store today and on a whim, bought a set of ARP head studs thinking that would help ensure I had the heads and gasket lined up right as I installed them and would give more accurate torque.
Any thoughts on using studs vs bolts? Also, any experience with studs on a 427 in an ERA - or other "original" sized engine compartment? I'm wondering if I can pull the driver side head off the studs with the close spacing to the driver footbox.
Olddog - thanks for the tips. I will try some of the more simple ones and see if I can at least locate where the leak is coming from.
Will try to talk live to Keith tomorrow.
