Old 06-19-2006, 02:41 AM
Kanga's Avatar
Kanga Kanga is offline
Thanks for all the positive comments its great to have others appreciate your work, stiffy the build took two years. The power steering is quite easy as the CR uses a VL rack, I used the power rack and the pump was also V8 holden so it came together, the pressure line is braided Teflon hose which the local Enzed did for me and the return is a -6 line, which I had to change to clear the headers. Power rack has a larger head I used the original couple that holden use and cut the shaft off a manual rack, I machined up a shim and welded this into the couple. So the bottom uni joint, which I got from Ian remains the same. I do have some pics which I will try and find it is easier than trying to explain it.
Steve
