Old 06-19-2006, 02:54 AM
Philm's Avatar
Philm Philm is offline
Default Power steering
Craig,
AS Steve has said the power steering rack is a bolt up fit, the steering shaft is the challenge. I used the VL coupling and the bottom half of the VL intermediate shaft which is a universal joint on one end.
I cut Ians shaft and the Vl shaft, turned the VL shaft to the same dimater for 100mm then joined the two with a steel tube and pined and welded the ends.
I will put a pck in my gallery tonight.
Steve will you be going to the nationals in October, I hope so we can see your car in person.
The CR comminity is growing, good to see another on the road.
Phil
