Old 06-27-2006, 10:57 AM
EarlsflyinCobra's Avatar
EarlsflyinCobra EarlsflyinCobra is offline
Ouch Ouch Hot Sand
Cobra Make, Engine: Street Beasts w/302 Twin Turbocharged....Under Construction!!
Send a message via AIM to EarlsflyinCobra
Default Remote Oil Filters
The below excert is from the Ford Racing site............So what size lines do you run???? It does not say???????????????????
If using a remote oil filter mount or oil cooler, make sure that all of the components are large enough to eliminate any restrictions to oil flow. Many Cobra replica kit cars use components that are too restrictive.
I was searching to find routing when I found the above........................
Also, what is the proper routing??????
1. Out of engine
2. Into ??
3. Out of ??
4. Into ??
5. Out of ??
6. Into ??
7. Out of ??
8. Into ??
9. Out of ??
10. Into ??
11. Out of ??
12. Back into engine
Choices to fill in are; Remote Oil Filter, Oil Cooler, Engine Pre-Oiler, Turbo After Oiler, and Turbos.
Safe Flyin, errrrr Drivin, Earl
