Old 06-27-2006, 01:05 PM
RobV's Avatar
RobV RobV is offline
Cobra Make, Engine: B&B, 351 W, TREMEC 600
Oh, the hood scoop! Mine was 3/4" off. Check out the picture below. Unfortunately, I didn't discover it until the stripe was on. I fixed both the scoop and the license plate light position. Both looked bad. B&B said it's just the way things are.
My wheels are Team III AC wheels. I like them. As I recall, the back spacing in the rear is 4 1/2" on 8" wide wheels and 4" on 7" wide fronts. However, I need to check these at home if you want to rely on them. I did take into account the recommendation in the B&B Manual (probably the only time I did). Check your tire manufacturer's recommendation on rim width and how it affects diameter.
Rob
