Old 06-27-2006, 12:34 PM
mike knight's Avatar
mike knight mike knight is offline
Cobra Make, Engine: spf 1837 408w 93mm turbo
Send a message via AIM to mike knight Send a message via Yahoo to mike knight
Default how high
wtm, interesting about the no thermostat. i'll pop one in there and let you know. as far as the guages are concerned i am using smiths which came with the spf. the fast engine management system reports engine temp as well and the two are within a couple of degrees. the fuel pressure is spot on. i had to disconnect the oil pressure gauge as it is mechanical and came loose from the sender. it started a small fire while on the dyno. i have since ordered an electronic gauge set by autometer.
BAD ASP
spf 1837 408w intercooled turbo t56 viper 6spd
95 mustang cobra 408w vortech t trim supercharger
71 torino cobra 429 scj
66 ford galaxie 7 liter
68 buick wildcat 430
