Old 06-27-2006, 10:58 PM
Aussie Mike's Avatar
Aussie Mike Aussie Mike is offline
That looks like a good setup Dale, very neat.
I also cut off Ians cross member mounts as I thought they were in an awkward position. I welded new ones in with nuts welded on the back so you just screw straight up into them.
I did a nolathane one using spring shackle bushes. I've changed it a bit since this one and the mount now bolts to the cross member rather than welded. makes it much easier to remove and work on.
Newer mounts that I've supplied with gearbox conversions use Ians original cross member position. I've also switched to rubber bushes because I reckon the nolathane bush hasn't got enough give compared to the flex in the engine mounts.
I've got a pic of the newer design on my home PC somewhere. I'll try to find it and post it.
Mike Murphy
Melbourne Australia
