Old 06-28-2006, 12:32 PM
Power Surge's Avatar
Power Surge Power Surge is offline
If you have a flat tappet cam, then you should be using an iron gear. Steel gears and brass gears are for steel roller cams only. If you use a brass gear on a flat tappet cam, you'll kill it in..well.. the time you killed yours .
Sal Mennella
