Old 06-29-2006, 12:39 AM
Carnut427 Carnut427 is offline
Cobra Make, Engine: ERA 427 w/496 Side Oiler, roller, dual quads
Whatever you change to get more throw will also make the mechanism harder to push unless you keep the same size proportion between the master and slave. I had the same problem, ended up grinding on some of the linkage from the master to the slave to acheive just a bit more throw, and it works fine. Obviously, having different make cars I don't know if this approach will work for you. Also, my slave doesn't allow the bearing to fully back off the clutch. I was told this would not be a problem. Almost 8,000 miles later it still isn't. The clutch does fully disengage, which is the important part. There just isn't a gap between the bearing and clutch.
Good Luck,
Dan
Do you know why they call it "PMS"? Because "Mad Cow Disease" was taken. --Unknown, presumed deceased
