Old 06-29-2006, 05:39 AM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
Jeff--
That is about what I envisioned--I think you maybe only broke the spider gears-- if you can get the rear cover off you probably can replace them without dropping the whole rear end--at least then you would be back on the road, and can convert to L/S at a later date--
And Ralpie is getting new spider gears also ( 31 spline from Strange Eng. axles) maybe he'll donate his old 28s to you----??????
See, all that carb work at the intake end overtaxes the output end
Jerry
