Old 07-01-2006, 04:39 AM
Mike Simard Mike Simard is offline
Cobra Make, Engine: Porsche 928 S4
Initial timing at 18 or so is a good thing on motors like these. Your motor will seem crisper off idle and will burn cleaner. You may need to limit the centrifucal advance travel in order to keep it between 18-34. I use to use an MSD distributor and had an adjustable vacuum advance modified so that it only provided 8 degrees travel, that also improved driveability.
